HBhat2
Contributor
5 years agoStratix 10 SoC Dev kit: Unable to connect Signaltap when HPS is enabled in the sof
We are using stratix 10 SoC kit. We enabled HPS along with DDR4 & Transceiver blocks. In quartus, we have set the "FPGA first configuration" mode (AFTER INIT_DONE). After that, generated the ...
JohnT_Altera
5 years agoHi,
Have you check if the CONF_DONE pin is high? Is the HPS FSBL loaded? The reason is that if the FSBL is not booted then it will impact the SignalTap detection.
