Stratix 10 I/O count discrepancy
- 4 years ago
These pins are unassigned so you can safely ignore it.
Thank you
I was able to reduce the IO count of my design, constrain all pins to I/O banks and eventually get everything to fit.
The current design has 371 pins in use and 3 spares, for a total of 374 pins ... which is the expected pin count.
I don't understand why the tools were reporting only 366 pins available before, but it is working now.
Quartus Prime Pro is actually now reporting that I am using 389 pins, however this includes 18 "unassigned" pins that are showing up in the output pins report (see attached image).
These pins are not part of my design and I don't know where they came from. Can these pins be safely ignored?
Terry
Thank you
- AminT_Intel4 years ago
