Stratix 10 emif time-limited programming file
Good day,
I have intel Stratix 10 GX 10M FPGA
I have Intel® Quartus® Prime Software SW-ONE-QUARTUS license.
I am using Quartus Prime Version 21.4.0 Pro Edition.
In my design I use emif only. But i get time-limited programming file after synthesis.
I see next log:
Warning(18391): Intel FPGA IP Evaluation Mode feature is turned on for the following cores
Warning(18392): "Nios II Embedded Processor Encrypted output" will use the Intel FPGA IP Evaluation Mode feature
Warning(265072): Messages from megafunction that supports Intel FPGA IP Evaluation Mode feature
Warning(265073): Messages from megafunction that supports Intel FPGA IP Evaluation Mode feature Nios II Processor
Warning(265074): Nios II Processor will be deactivated when the evaluation time expires.
Warning(265069): Megafunction that supports Intel FPGA IP Evaluation Mode feature will stop functioning in 1 hour after device is programmed
Info(115017): Design contains a time-limited core -- only a single, time-limited programming file can be generated
Info(21726): Time Limited Core Name: Nios II Embedded Processor Encrypted output (6AF7 00A2)
What am I doing wrong?
I need in other license yet?
Thank you,
Siarhei
- AR_A_Intel
Hello
Welcome to INTEL forum. To narrow down this issue, can you please provide me
1.license.dat file
2.screenshot error
3. assembler report .asm.rpt file
For privacy, you can also reply/attach file in private message
- sstrell
So you're not using a stand-alone Nios II f core in your design, which does require a license, only the EMIF IP? That's very strange.
- SiarheiLiavonenka
I found a solution for my problem. This is one options in emif "Use Soft NIOS Processor for On-Chip Debug". But I don't know that I need a special license for this option.
I set to disable.
Use Soft NIOS Processor for On-Chip Debug: Disable
- AR_A_Intel
With your confirmation. I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
