15 years agoYes the output lines from the SDRAM controller are connected to the corresponding output pins. I also get a warning about the SDRAM_CKE pin being stuck at VCC when it is also directly connected from the SOPC generated system to the SDRAM_CKE output pin. I have no clue what could be causing it. I will post my schematic later on when I get the chance.
