16 years agoThe asynchronous feedback modulo logic only works with an asynchronous ripple carry counter. Here the stages are toggling one after the other. I have build many similar counters with discrete TTL and CMOS logic in the past.
4count is a synchronous counter, so all outputs are toggling at the same time. Depending on accidental delays, you can get a reset glitch during the transition 3->4.
