11 years agoStrange bus failure
I am using Quartus 2 schematic entry for my project. I have designed an RS232 uart and baud rate generator. On the board, there is a 4 digit LED display. At the top level, if I connect the...
11 years agoWithout the source, it will be difficult to diagnose
As long as the named nets are in different files, there should be no problem (if it was trying to connect 2 things to the same net, you'd get an error). Is your design fully synchrnonous?
