11 years agoStrange bus failure
I am using Quartus 2 schematic entry for my project. I have designed an RS232 uart and baud rate generator. On the board, there is a 4 digit LED display. At the top level, if I connect the...
11 years agoIt is most likely a problem with your design. A circuit cannot ~"forget" how to work.
Have you got a simulation test bench? did the results do as you expected?
