10 years agoStore complex decimal values as 2D array in a rom in verilog
I need to perform convolution between 2 matrices in verilog : a 7x7 matrix that holds complex double values and a 72x300 matrix that stores double values. How should I store such a matrix in ro...
10 years agoIf you have a verilog or VHDL file opened in Quartus you can try inserting a ROM template that will drop in code that implements a ROM. If I remember correctly it's under "edit" --> "template"
