Still no support on the localparam on "parameter_port_list". When will it available?
I had "Google" the problem of {Error (10170): Verilog HDL syntax error at LA_BIT_BUFFER.sv(4) near text: "localparam"; expecting an identifier ("localparam" is a reserved keyword ). }. I found nearly identical problem on stackoverflow. It is a 2015 post. Now, nearly 2019. It still not FIX!!!!!
- Vicky1
Please check the below solution & provide the following details,
- Quartus edition & version used.
- Can you provide your design code?
Best Regards
Vikas Jathar
- escottp
Hello @Vicky1
Do you know if there has been any attempt to resolve this issue. I am on Quartus 20.1.1 and there still appears to be no support for a localparam to exist in the module port list (despite that feature being a basic part of the language).
In your previous reply to this post, you provided a link. That link directs us to the generic "FPGA Knowledge Base" page, not to a particular solution. Please advise!
Thanks!
