15 years ago --- Quote Start --- Yes, of course it is the output pin assignment. No big deal if you can't change it. Most people ignore that warning. --- Quote End --- Hi, vjAlter, Thank you for your detailed explanation, I have found the solution just now. I turned to the pin document of the device and I found that there are PLL dedicated output pins!! If I change the pin assignment of the pin, the warning will disappear and what's more, I will get better output clock! :) Thank you so much! And here is another discussion on this topic and they solved it perfectly, hope it will be a good reference to you too. :) http://www.alteraforum.com/forum/showthread.php?t=5014 (http://www.alteraforum.com/forum/showthread.php?t=5014)
