10 years agoSTD_LOGIC_VECTOR error
I'm trying to implement following verilog peace of code in vhdl reg [11:-2]center; it's clear center is an 14 bit register. but in vhdl signal center : std_logic_vector(11 downto -...
10 years ago --- Quote Start --- thank you for the quick reply sir, what if i used following code instead using std_logic_vector signal center: integer range 0 to 16384 -- (13 downto 0) will it be the same ? --- Quote End --- Almost, I think you mean: signal center : integer range 0 to 16383; As this is 14 bits. 16384 requires 15 bits. But you still have the same problem as I outlined above - you need to offset everything else, not just the center signal.
