9 years agoStateMachine States in SignalTAP
I am not able (anymore) to observe the state machine's states in SignalTAP. I was trying to Import the states from the *.stp in order to get the Mnemonics as it once worked for one hot coded states, ...
9 years agoI think he's referring to the state machine tapping feature in SignalTap, allowing you to create a mnemonic table based off the coded states. If you've made a change to your machine that is preventing the tool from "recognizing" your state machine, you would have the issues mentioned. Check the state machine viewer debug tool to see if your state machine is being recognized. If it's not, you've changed something in your code that is preventing recognition.
