8 years agoState Machine Viewer - missing transition
Hello every one, can you explain me why I get different state transition diagram from relatively the same VHDL? Here is the code: 1) if rx_bit_in...
8 years agoHi Emil,
--- Quote Start --- The both IFs are with in a clocked process within a case. The IFs are just the transition condition to the next state, and they are equivalent: when 7 -> transition else count. I can describe as count if < 7 else transition or count and if = 7 transition. In the simulation it is corect in real test too but the state machine viewer do not like the "<" sign :) --- Quote End --- Can you check with either if rx_bit_index <= 6 then --the difference is here OR signal rx_bit_index : integer range 0 to 8 := 0;if rx_bit_index < 7 then --the difference is here I am able to see the state transition to s_rx_stop_bit in the state machine viewer. Check Screenshot. Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards Vikas Jathar Intel Customer Support – Engineering (Under Contract to Intel)
