8 years agoState Machine Viewer - missing transition
Hello every one, can you explain me why I get different state transition diagram from relatively the same VHDL? Here is the code: 1) if rx_bit_in...
8 years agoI believe both variants are functionally equivalent. I don't see any ambiguity (at least in the posted code snippet). I presume there are neither state overrides below the case construct.
The fact that the state machine viewer misses the state transition to s_rx_stop_bit, which apparently occurs both in simulation and synthesized code, seems to indicate a bug.
