8 years agoState Machine Viewer - missing transition
Hello every one, can you explain me why I get different state transition diagram from relatively the same VHDL? Here is the code: 1) if rx_bit_in...
8 years agoYes, you are right saying that in the second variant the state change at any value greater than 7. But the first value at which there is a transition is 7, and Quartus do not show this. Why?
Else the declaration of rx_bit_index is signal rx_bit_index : integer range 0 to 7 := 0; And the index is set to 0 after reaching 7. I mentioned that "In the simulation it is corect in real test too" It work (the both codes) on MAX II device and is correctly behaving in ModelSim Regards, Emil
