11 years agoState machine unstable
Hi, I'm sort of new to Verilog (only used it for a few months) but I have worked with HW and SW design for a long time. Verilog seemed fun and I went ahead to try it on a cool project. htt...
11 years agoHi Jonase,
As you mention "It says it can run my design at 115MHz, and I run at 100MHz, so it should be ok. I'm using about 50% of the gates and 90% of the RAM". Is really a timing issue, are you able to do some timing analysis, and confirm which path have a longest path that fail setup and hold time.
