9 years agoState machine counter problems
I do not understand why my state machine does absolutely nothing. Can anyone identify why? It seems simple enough to me, 4 states that have three possibilities based on two inputs (2 state changes an...
9 years agoYour code will not compile. Apart from 2 clocks, they are not the outermost part of the process.
You really need to do 2 things. First of all, draw your circuit out on paper. Without knowing what your circuit should be, you shouldn't be writing HDL. Second, using that circuit, read up on how to code those components.
