9 years agoState machine counter problems
I do not understand why my state machine does absolutely nothing. Can anyone identify why? It seems simple enough to me, 4 states that have three possibilities based on two inputs (2 state changes an...
9 years agoThank you, this gives me material to think about for sure. Given my signal I thought it would trigger counts and restrict any loop counts. I changed the code to change states on edges of my signal, but now my variables depend on multiple clock edges. My signal will always look like what is shown, two square waves with a 90 degree phase difference (50% duty cycle, varying period, and process can reverse in time). This is a piece of scientific instrumentation that is fundamentally asynchronous so it would be nice to avoid a master clock and only depend on these two inputs (blasphemous or not).
https://alteraforum.com/forum/attachment.php?attachmentid=14226&stc=1
process (Ain, Bin, present_state)
-- Counting variables
variable c12, c23, c34, c41, c43, c32, c21, c14: unsigned(25 downto 0):="01000000000000000000000000";
begin
case present_state is
when st1=>
if (rising_edge(Bin)) then
c12:=c12+1;
next_state <= st2;
elsif (rising_edge(Ain)) then
c14:=c14-1;
next_state <= st4;
else
next_state <= st1;
end if;
when st2=>
c23:=c23+1;
next_state <= st3;
elsif (falling_edge(Bin)) then
c21:=c21-1;
next_state <= st1;
else
next_state <= st2;
end if;
when st3=>
if (falling_edge(Ain)) then
c34:=c34+1;
next_state <= st4;
c32:=c32-1;
next_state <= st2;
else
next_state <= st3;
end if;
when st4=>
c41:=c41+1;
next_state <= st1;
elsif (rising_edge(Bin)) then
c43:=c43-1;
next_state <= st3;
else
next_state <= st4;
end if;
end case;
out12<=c12;
out23<=c23;
out34<=c34;
out41<=c41;
out43<=c43;
out32<=c32;
out21<=c21;
out14<=c14;
end process;
--- Quote Start --- There are several things wrong here: 1. Because of the way VHDL works, your outputs will only change when Ain, Bin or present_state actually change. Be warned - the way you have your circuit will mean that the code will behave differently to hardware. 2. How would you expect the counters to work. Your code implies that the counters should add one when conditions are met - but they will keep adding 1 in a feedback loop. You need to move the counters to a clocked process to actually work as expected. --- Quote End ---
