8 years agoSPI slave clock crossing domain?
I have a question about synchronization between clock domains in SPI slave. I need to design a SPI slave module, which has SS (slave select), SCK (SPI clock), SDI (data in from master), SDO (Data ...
8 years ago --- Quote Start --- I have done an SPI design using a 200MHz system clock in the past. It worked very well. IIRC, it was on a Virtex 4 To answer the questions: 1. Thats basically the only way to do it. 2. There is enough margin to allow for this in SPI. At 200 MHz, a couple of clocks margin here or there is insignificant compared to the SCK --- Quote End --- Thanks Mr.Tricky for giving your opinion! --- Quote Start --- 1. Thats basically the only way to do it. 2. There is enough margin to allow for this in SPI. At 200 MHz, a couple of clocks margin here or there is insignificant compared to the SCK --- Quote End --- Your answers are very short, but they are clear and enough information that I need!
