8 years agoSPI slave clock crossing domain?
I have a question about synchronization between clock domains in SPI slave. I need to design a SPI slave module, which has SS (slave select), SCK (SPI clock), SDI (data in from master), SDO (Data ...
8 years agoUsing separate synchronizers for the SPI input signals is basically O.K. Standard SPI timing has sufficient margin to allow for skew and jitter in the resampled signals.
I would be however worried about the uncomfortable high 200 MHz system clock, which can work for simple digital logic but isn't well suited as general system clock in my view. I have implemented 20 MHz SPI slave units with more compatible 40 MHz system clock, running the SPI unit in the SCK domain with domain crossing data path.
