9 years agoSpeed up data-transfer between Host and Device
Is there a way to speed up the data transfer between Host(ARM) and Device(CYCLONE V)? I need to load an uchar array of the size 672 x 2993 to the FPGA -> compute on this array -> get results fr...
9 years agoReplacing
*src_ptr = *img.data; with memcpy ( src_ptr, img.data, sizeof(uchar) * size_cols * size_rows); worked but know it have a copy in my code again (no improvement in regards to runtime). Using this src_ptr = img.data; Gives an empty output (as always). Do you have an idea how to handle it without the memcpy-function? Thanks
