IDeyn
Contributor
7 years agoSource Synchronous representation in TimeQuest - FPGA is a transmitter
Hi all. I have some things to discuss about Source Synchronous representation in TimeQuest. I attached the project, which is slightly modified version of Source Synchronous Analysis with TimeQuest ...
sstrell
7 years agoThis is a stupid question, but are the correct clocks from the PLL connected to the data DDIO (and clock DDIO) in your design? Like you said, it doesn't make sense that you're seeing data path analysis with a PLL output as the from node.
#iwork4intel
- IDeyn7 years ago
Contributor
Hi sstrell.
Yes, I'm sure, that clocks from the PLL are connected properly to the DDIO. I attached a simple project, and just've checked it.
Thank you.
Ivan
- IDeyn7 years ago
Contributor
Hi sstrell.
Is there any update for an issue, did you see the attached project?
Ivan
