10 years agoSource Synchronous mode in different quartus version
hi, everyone, I have a design using alt_pll Source Synchronous mode, and I make the data input pin "rx" an PLL Compensation assignment. When builded with Quartus 9.1, the "rx" input register...
10 years agoDid you regenerate the IP when you switched versions? Or did you throw the old IP at the newer tool? If so, try regenerating the IP.
If you did regenerate the IP - and you're sure it's parameters are like for like - then differences in behaviour like that, between Quartus versions, should certainly be put to Altera. Raise a ticket via mysupport (https://mysupport.altera.com/alteraservreq/mysupporthomeclassesview.html). Cheers, Alex
