8 years agoSource-Synchoronous Interface: Edge Aligned SDR Clock constraint
Hi. Iam designing using a Cypress FX3 device (CYUSB3014-BZXC) and a Cyclone IV FPGA(EP4CE115F29C8). The FPGA has a external 50 MHz oscillator. The design shouldrun @ 100 MHz. To do this I have...
8 years agoI can see that just the failing lines are the lines conected to pins T7 and T8. Those are VREF pins. All the other are not. It this can be the issue? I heard about the higher capacitance for these pins. Maybe is this the problem? Can this be mitigated in some way?
