13 years agoI generally don't use the pre-canned I/O analysis, but create my own TQ_analysis.tcl file and put stuff in like so:
report_timing -setup -npaths 50 -detail full_path -to [get_ports {m_data_p[*]}] -panel_name "m_data_p||setup" report_timing -hold -npaths 50 -detail full_path -to [get_ports {m_data_p[*]}] -panel_name "m_data_p||hold" I do it for most interfaces and so the reports are tailored to those interfaces. (Anything you miss still shows up in the summary/hold/recovery/removal reports, so if something failed you'd know about it). Now if the above says no paths exist, it needs to be analyzed why. (I'm not sure on first glance, but fixing the create_generated_clock shouldn't have broken anything. Did the paths show up before?
