13 years agokaz,
mclk_p is a muxed clock: it can be clkA, clkB or the PLL output clock. So, the way he is constraining it looks correct to me. kkoorndyk, If clkA, clkB and gxb_refclk are unrelated, then you probably should cut all paths between them from analysis (ie, set them in separate clock groups) and use clock domain crossing techniques, if needed.
