17 years ago
SopC Builder n System Console
hi there,
i've already checked out for a similar threat, but there isn't.
So i have the following problem:
I want to control within a Jtag to Avalon-Master Bridge a Register where i can program a constant, all with the System Console Interface.
So i found an example the "LED Lightshow Example", introduced in the "System Console User Guide".
So that comes quite near to my problem i think. In addition i've checked out that example, all works fine. I can change the value of the constant in System Console and another LED blinks up (i have removed the accelerator)
Next i tried to build up this example on my own, to understand how things work in SOPC Builder and so on (i am a beginner on this)
So i started SOPC Builder and took a Avalon Memory Mapped Master and a Simple PIO where I modified Options to "Output Ports only" Width: "8".
I connected the Master and the PIO, all works finde.
I don't want to use this accelerator thing to have a running light, so forget this!
Then i generated the code.
Then i created a Symbol Block from the Verilog-Code
Next i created a Schematic File
where i dropped the Symbol-Block.
In the last step i assigned the PINS to the Output of the bevor created Symbol Block.
I loaded the code into my Cyclone II Starter KIt in a EP2C35F672C6N FPGA.
All works fine.
Now i want to control the LED's, i started SOPC Builder's System Console.
Then i opened the Master.
All works fine to this point.
Now i want to write a value in a register, with "master_write_8 $jtag_master 0x0 192" With the value 192 to have 2 LED's on.
But that doesn't work, it's like it try to write but nothing happens.
I couldn't use the Console anymore, so i hae to close it.
So what is the problem, could anybode help me plz? I'm new on this. :D
greetings elec
1 Reply
    Ive seen this happen if your sopc system is held in reset. You may want to tie the reset line to vcc to be sure.
