18 years agolinks worked, it is my bug. i give dinamic link for files(this is example links).
--- Quote Start --- From my understanding there are other ways to develop advanced components that can change port widths etc) that are used by Altera Megacore and Altera's IP developers (AMPP partners) - are you an IP developer or just building componets for your own/company's projects? If you submit a service request at Altera's mysupport (www.altera.com/mysupport) and give them an example design of your problem, they might be able to answer your questions or provide you with the information you are looking for. --- Quote End --- It is own(company) components and it must be highly configurable as possible for reuse. Some components may be used in some different devices with very different options. All my ptf components are handwritten, and uses many perl extensions. For example - i need write software --- Quote Start --- I would also recommend to look at the Nios Forum (www.niosforum.com - A link is also available from the main topic list on the alteraforum) for users who are much more experienced with SOPC Builder and building componets. If you look at the projects link there you can find some users who have shared their own developed IP. Perhaps you can find the help you are looking for there. --- Quote End --- I know about niosforum, and if you see - all components in old format. This components will be slow or less informative in new gui, because altera hide access for new gui( Now, i think that i need write software which will create component for sopc builder...but it's not simple pushbutton interface... i'll try to use tk
