18 years ago --- Quote Start --- I have changed links. Some components requires many configuration options(number of buses[2-3], type of buses - burst support or simple access, numer of channels and it's parameters). Where can i find more info about java interface and example? --- Quote End --- Hi nvs, Tried your new links and got the following error: Sorry, but you enter an incorrect validation code or this link deleted by timeout. Perhaps if you put it on a public site like Yahoo's flickr.com it might be more accessable. From your description, it seems you are using more advanced features of building components that what is documented for component editor for most users. I am only familar with the component editor flow that is documented ( and a little bit with the old interface to user logic tool). From my understanding there are other ways to develop advanced components that can change port widths etc) that are used by Altera Megacore and Altera's IP developers (AMPP partners) - are you an IP developer or just building componets for your own/company's projects? If you submit a service request at Altera's mysuppor (http://www.altera.com/mysupport)t (www.altera.com/mysupport) and give them an example design of your problem, they might be able to answer your questions or provide you with the information you are looking for. I would also recommend to look at the nios forum (http://www.niosforum.com) (www.niosforum.com - A link is also available from the main topic list on the alteraforum) for users who are much more experienced with SOPC Builder and building componets. If you look at the projects link there you can find some users who have shared their own developed IP. Perhaps you can find the help you are looking for there. Regards, -ATJ [UPDATE] I figured out how to post images on the forum :) (There is a section called "Additional Options" under the post window. Adding nvs images to this topic to see if anyone can offer any additional help on building advanced components. Ciao. -ATJ
