18 years ago --- Quote Start --- I've had the same problem with the tri-state bridge on 7.1sp1. I posted a service request to Altera and mentioned the patch which was supposedly available. I was eventually told that this was a bug but wasn't offered a patch. I have been told that it will be fixed in the next release, and in the meantime I should revert to 6.1. Maybe the patch is only available for the subscription edition of Quartus? The patch for Web Edition available for download (v1.13) doesn't fix this bug. --- Quote End --- Hi sharkybaba, You should reference my previous post in this topic on the patch version needed. I would think it may be worth while to try the patch on the web edition (be persistant in requesting the patch to see if it would help solve your problem - it seem to help jcn). The web and subscription tools are very similar with only fewer devices available and a few advanced tools not included in the web edition. The patch I installed only replaced a few files in my system when I did a date/time check after installing the patch. Hi jcn, Glad to hear the patch work for you. Cheers, -ATJ
