18 years agoHi TylerCoen,
There is a software patch for the tri-state bridge problem you described. In 7.1 when you add a custom tri-state component, it causes the tri-state bridge to give a java exception error. I added the patch to my design and it solved the java error and allow me to share my pins. You can request patch 0.20 for Quartus II version 7.1 from mysupport. It should be identified as a patch to fix a SOPC builder tri-state slave problem Regards, -ATJ
