10 years ago
SomeQuestions about the virtual jtag TCK
I tried to send a 800*480 image throw the vjtag,here is the tcl:
        puts " Begin to read..."
		set run_width 0
		set run_height $height
# 		puts
			device_unlock
			set pix_array(,$run_width) $pixel
			incr run_width
# 			puts "The pixel is $pixel"
			incr run_height -1
			set  run_width 0
			puts "Line.......$run_height"
but the time to send all the data is so long,about 20min,during the process I use the oscilloscope to measure the TCK pin of the usbblaster,it is about 200kHz,the Virtual jtag megafuntion handbook noted:
Note that TCK (a maximum 10-MHz clock, if using an Altera programming cable) provides the clock for the entire SLD infrastructure.
And the usbblaster ii download cable user guide:The USB-Blaster II download cable has a default TCK frequency of 24 MHz.
I catch the waves throw the signaltap,
http://www.alteraforum.com/forum/attachment.php?attachmentid=12802&stc=1 the shiftting takes about 96 Ttck when translatting the 24 bits data,even though,the image has 800*480 = 384000 24bit datas, 384000*96 = 36864000,when the tck is 200kHz,it should takes about 36864000/200000 = 184s,about 3min,
I don't know why the transmission is so slow,does anyone can help me?
    		set run_width 0
    # 		puts
    			device_unlock
    			incr run_width
    			incr run_height -1
    			set  run_width 0
    I catch the waves throw the signaltaphttps://www.alteraforum.com/forum/attachment.php?attachmentid=12809 ,
