Altera_ForumHonored Contributor16 years agoSome problems with SOPC builder I don't know if you have the following issues with the SOPC builder. 1. Within the SOPC builder, you can use the pll or Avalon altpll component. When I select the "pll" component, I am uable t...Show More
Altera_ForumHonored Contributor16 years agoCould you post the component HDL file and SOPC system screenshot?
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
