Solution for Programmer problems on 64 bit windows in Quartus 12
Hi, I am having the same problem as here :
So, I downloaded and installed Quartus II web edition on Windows 10 64 bits machine, I installed properly the USB Blaster cable and its drivers.
All seems to work except that going into "Hardware Setup" will not find any hardware cause "error 82" which means the jtag server is not running, in fact it's not.
Going into the BIN64 directory and trying to launch jtagserver --install opens an error window saying "The code execution cannot proceed because the tbbmalloc_proxy.dll was not found" ..
In fact it's NOT in the same directory.
Trying to launch the 32 bits version says :
"The 32 bit jtagserver does not run on 64 bit windows.
Please run the version from the bin64 directory instead."
Copying the dll form the "bin" folder in the "bin64" folder and trying to launch the server again gives "error 0x0c0000f7" ..
OK clearly is missing the 64 Bits version of that DLL .. how can we fix this ?
There was a LINK in a web page of yours that in theory was pointing to a .zip with that DLL to download but that link goes to an empty "Error 404" page.
So is this solution/files you uploaded "validated by Intel", I mean can I try to use those files in that .zip safely ?
Thanks in advance.
Cheers.
