ERagu
8 years agosof2flash command through Nios II shell not working
I'm developing on Windows 10 for the Arria V GX Starter Kit. For the past year or so, when I've wanted to write to non-volatile memory, I took the output .sof file from Quartus and run it through th...
- 8 years ago
Well, I just checked the command from a Windows 10 NIOS-2 prompt and it works fine. Check that the SOF file has been generated using the latest 18.1 version of Quartus. This could happen if you're using an SOF created by an earlier version.
ERagu
8 years agoAbe's answer worked, it turned out I was using a different version of NIOS than the version of Quartus I was using to compile.
