13 years agoSOF file
Where do I find the location of the final output programming file (e.g. sof file) after a I have performed a full compilation? How do I set its location and type? Thank you.
I found the problem, at least part of it from assembler report.
--- Quote Start --- Can't generate programming files for your current project because you do not have a valid license for the following IP core or cores. Warning (115005): Unlicensed IP: "Nios II Processor(6AF7 00A2) --- Quote End --- So the question is why can I not generate the opencore version of NIOS?
