9 years agoSOF-file works correctly, POF-file does not
I made the simplest of the simplest NIOS II
applications: a LED that blinks endlessly. I have a SOF- and POF-file created by Quartus Prime 16.0.0. Programming the SOF-file and running the NIOS II application results in a continuously blinking LED. However, programming the POF-file and power cycling the MAX 10 development board gives a LED that blinks for about one second. After that it stays lit. Any clues? [ Solution: apparently it is due to printf statements in the NIOS C-code. Removing them solved the problem. ] Thanks, JosNo RepliesBe the first to reply
