8 years agoSmall mistake in clCreateBuffer crashes PCIe
I made a really simple mistake. I have created a 16 byte buffer but transfered 24 bytes to FPGA global memory. This was crashing the PCIe. I have to restart the entire system because of this small er...
8 years ago --- Quote Start --- What do you mean by FPGA reconfigration in this scenario? Do you mean mismatch in aocx file for the host program? --- Quote End --- No, without any mismatch or any incorrect settings, FPGA reconfiguration on Arria 10 could hang or crash at run-time due to timing issues associated with partial reconfiguration. If your OS hangs/crashes right after "Reprogramming device [0] with handle X" is printed, then it is crashing because of the reconfiguration. This is a random issue and is not necessarily reproducible even with the same binary.
