11 years agohatter: yes, you can cut the path to the synchronizer. Altera doesn't do that just in case you feed it with a reset and the same domain and want it to be timed, but it can be cut.
kaz: I'm not sure I follow what you mean about the D input to the counter. The counter is not enabled to increment since all reads are disabled, so it doesn't matter what is at the D input since it will be ignored.
