12 years agoSize and persistence of __local memory
Hi, I was trying to understand the implementation of __local memory better and have two questions. 1. Max size of local memory ------------------------------- If I am not completel...
12 years agoKeep in mind that if your kernel attempts to read from __constant memory and the contents are not already cached, the latency to fetch the data from global memory will be much higher. In general I only use __constant memory if I know the entire buffer will fit into the constant cache.
