12 years agoSize and persistence of __local memory
Hi, I was trying to understand the implementation of __local memory better and have two questions. 1. Max size of local memory ------------------------------- If I am not completel...
12 years agoThanks for the quick and informative response! That all makes perfect sense and I think I understand much better now.
I will experiment with __constant parameters a bit, maybe they are more appropriate for what I wanted to do anyways (load a big matrix only once and use it many times). Let's see how much const memory I can get out of my system (using the --const-cache-bytes <N> aoc compiler flag). Otherwise I can always declare my kernel to be a task.
