8 years agoSISO testbench and waveform HELP
Hello, i am new to VHDL and i want some directions. I want to make a Serial in serial out 4 bit shift register, but my waveforms in output have some red marks as you can see below. https://alter...
8 years agoSOUT is an output from the UUT. Therefore the UUT sets the value of Sout. If it is always 0, then there is a problem with the UUT, or th way you're driving the UUT.
The X values occur because you are driving '1' against the value of '0' from the UUT. I also notice you are generating enable like a clock. and therefore likely never actually enabling the UUT. It needs to be set for full clock cycles, not half cycles.
