8 years agoSISO testbench and waveform HELP
Hello, i am new to VHDL and i want some directions. I want to make a Serial in serial out 4 bit shift register, but my waveforms in output have some red marks as you can see below. https://alter...
8 years ago --- Quote Start --- You're driving Sout in the testbench, and the UUT is also driving Sout. Only the UUT should be driving SOut. --- Quote End --- You mean i should not change the values of Sout in the process? When i do it Sout is always 0.
