11 years agoSingle Work Item Kernel Optimization Report Not Generated
Hi, I'm trying to the use the optimization report which the aoc generates for single work item kernels. Unfortunately I can't get the compiler to generate the full report (at least one which r...
11 years agoThe second command is not a valid command. The compiler does not create the profile.mon file so you cannot force it to make it. The file is created after you run the code on the FPGA because that's where it gets the data from. You should see it in your current working directory. I'm not sure why you cannot see it.
