11 years agoSingle Work Item Kernel Optimization Report Not Generated
Hi, I'm trying to the use the optimization report which the aoc generates for single work item kernels. Unfortunately I can't get the compiler to generate the full report (at least one which r...
11 years agoHow are you trying to view the profile information. After you compile with --profile, run the program. After you run the program a profile.mon file should appear with the information from the profiler. Then you can view the it in the profiler GUI using aocl report <.aocx file> profile.mon.
