11 years agoSingle Work Item Kernel Optimization Report Not Generated
Hi, I'm trying to the use the optimization report which the aoc generates for single work item kernels. Unfortunately I can't get the compiler to generate the full report (at least one which r...
11 years ago --- Quote Start --- I had trouble trying to find that information as well. However, one thing that might help is to compile with the --profile flag and use the profiler to see more information about your design. The profiler is very limited but does provide some insight into your kernel in terms of memory accesses and bandwidth so you can quickly see if you're memory bounded or if it's something in terms of your computation. --- Quote End --- Sorry, why im not getting any report even when im using "--profile"?and the error im getting is unreadable!(like the figure below)
