9 years agoSingle Clock vs Multiple Clock
Hi all, I have a question about the clock signals. Say if I have a large scale of a network, where each node in the network is doing some operations. What if I use multiple clock signals, which...
9 years agoIf you have failing paths, the easiest way to fix it is to improve pipelining in the code. These probably occur from to much logic between registers
