17 years ago --- Quote Start --- yes, but I thought I would be able to do the following: when sinewave > fpga threashold , fpga will output 1. when sinewave < fpga threashold , fpga will output 0. so if I use a sinewave with a minimum value = 0, that is a normal sinewave with a positive offset, the fpga will act as if its cutting the upper and lower edges of the sinewave and outputs a clock.. isnt that right? --- Quote End --- Hi sonaiko, you have to keep in mind the maximum allowed I/O voltage ( depends on the Device family). Negative voltage should be avoided ( could damage your device). But with this restriction it should work. I'm not sure, but maybe your duty cycle is not exactly 50 %. There is no need to implement a "slicer" inside the FPGA, the I/O cell will do it .
