PLuni
6 years agoSimulation window is not opening
Hello! I'm trying to launch project on ubuntu 18.04. Compilation was successful. Then I start RTL simulation which is also successful, but simulation window is not opening and nothing happens. Am ...
- 6 years ago
Actually, I fixed it. Instructions from here https://askubuntu.com/questions/1121815/how-do-i-run-mentor-modelsim-questa-in-ubuntu-18-04 made it work.
PLuni
6 years agoI have Quartus Prime Lite 19.1. Here is what happens when I start RTL simulation.
Also I tried to start modelsim manually and it produces the following error
Failed to obtain lock: couldn't open "/home/user/.modelsim_lock": file already exists
Error in startup script:
Initialization problem, exiting.
while executing
"Transcript::action_log "PROPREAD \"$key\" \"$value\"""
(procedure "VsimProperties::Init" line 59)
invoked from within
"VsimProperties::Init $MTIKeypath"
(procedure "PropertiesInit" line 18)
invoked from within
"PropertiesInit"
invoked from within
"ncFyP12 -+"
(file "/mtitcl/vsim/vsim" line 1)
** Fatal: Read failure in vlm process (0,0)So, it looks like modelsim is not working properly for some reason.
PLuni
6 years agoActually, I fixed it. Instructions from here https://askubuntu.com/questions/1121815/how-do-i-run-mentor-modelsim-questa-in-ubuntu-18-04 made it work.
