PLuni
6 years agoSimulation window is not opening
Hello! I'm trying to launch project on ubuntu 18.04. Compilation was successful. Then I start RTL simulation which is also successful, but simulation window is not opening and nothing happens. Am ...
- 6 years ago
Actually, I fixed it. Instructions from here https://askubuntu.com/questions/1121815/how-do-i-run-mentor-modelsim-questa-in-ubuntu-18-04 made it work.
AnandRaj_S_Intel
6 years agoHi Polina,
What do you mean by RTL simulation successful but simulation window not opening.
Can you attache image and elaborate steps.
Also tell about Quartus tool version & edition used.
Anand
- PLuni6 years ago
I have Quartus Prime Lite 19.1. Here is what happens when I start RTL simulation.
Also I tried to start modelsim manually and it produces the following error
Failed to obtain lock: couldn't open "/home/user/.modelsim_lock": file already exists Error in startup script: Initialization problem, exiting. Initialization problem, exiting. Initialization problem, exiting. while executing "Transcript::action_log "PROPREAD \"$key\" \"$value\""" (procedure "VsimProperties::Init" line 59) invoked from within "VsimProperties::Init $MTIKeypath" (procedure "PropertiesInit" line 18) invoked from within "PropertiesInit" invoked from within "ncFyP12 -+" (file "/mtitcl/vsim/vsim" line 1) ** Fatal: Read failure in vlm process (0,0)So, it looks like modelsim is not working properly for some reason.
- PLuni6 years ago
